Which circumference value do I have to use?
spiceagent11
Re: Which circumference value do I have to use?
Postby spiceagent11 » Thu Oct 28, 2021 5:09 pm
I recently got the Suito and after the calibration I had a few rides to test it out. I noticed that the power reasons are low compared to my usual so I did a ride with the Favero Assioma and as suspected the power is too low. I did recalibrate but it’s the same.
[urlhttps://]vidmateapp.win[/url] | moviezwap | spice money login
Postby Elite Admin S » Fri Oct 29, 2021 11:16 am
Contact our customer care:
Specify the problem and the trainer serial number.
amanda9nunes
Postby amanda9nunes » Tue Feb 08, 2022 1:47 pm
Wheel diameter = (rim diameter) + (tire diameter * 2). Wheel circumference = Wheel diameter * PI. You should try this formula
Users browsing this forum: No registered users and 41 guests
