Terrible sound from my drivo
nkonovski
Re: Terrible sound from my drivo
Postby nkonovski » Mon May 04, 2020 4:22 pm
kspaar66 wrote:I've another unexpected noise from my new (3month) Drivo II. The plastic body is creaking.
See here https://www.youtube.com/watch?v=s77k4WHmC_M.
Where is it coming from and how can this be fixed?
Is there any solution, yday just spot my drivo do make the same plastic creaking noise.
Not sure where exactly is the problem, but the noise come just like in the video when push the bike from side to side
kspaar66
Postby kspaar66 » Mon May 04, 2020 9:58 pm
I’ve sent back my device to Elite (without cost). They said that they had ‘just’ to tighten the free wheeling hub. Was ok when it came back ...
nkonovski
Postby nkonovski » Tue May 05, 2020 8:26 am
Thanks for replay.
Interesting, yday just remove the plastic cover from one side and try to do side pressure and seems to not make any noise so I made a conclusion that problem come from plastic cover (my unit have broken cover from the day one).
But will try to tight free wheel hub if possible
Postby Elite Admin S » Thu May 21, 2020 8:35 am
@nkonovski,
if you are having any problem contact our customer care at myetraining@elite-it.com.
We will give you all the instructions to check the cause and solve the problem
michaelwestergaard
Postby michaelwestergaard » Wed Jun 10, 2020 3:45 pm
I removed the covers and lubricated the belts with silicone spray.
https://youtu.be/QH2p77PVak4
I also adjusted the belt tension after a test run after the lubrication as the belt slipped at bit when the gradient was 10%+
https://youtu.be/o797umVx1lw
If you need to adjust the belt tension just follow the description in the manual, but remember to tighten the locking bolt again afterwards as this step has not been included in the manual.
I now have a silent trainer again that feels smooth :-)
Return to “Drivo & Drivo II”
