Can I upgrade the firmware on my trainer to make interactive with online apps S/N 13473?
Digital Qubo Wireless Firmware 80
rafniem@gmail.com
Re: Digital Qubo Wireless Firmware 80
Is that mean that after software upgrade trainer can be control by zwift? Does it change resistance based on the elevation in zwift?
Thanks and Regards
Rafal
Thanks and Regards
Rafal
I have the qubo digital SN Q 2332 it is upgradable?
Thank you
Thank you
Hello, I have the qubo digital SN Q 2332 is it possible to do the upgrade?
Thank you
Thank you
Guys,
Qubo Digitals are upgradable from serial number 9784.
Arion Digital is upgradable from serial number 903
In this way you all can check by yourself
Guys,
Qubo Digital is upgradable from serial number 9784
tomaz.sosic
I have an Elite Turbo Digital Qubo Wireless, can I update the firmware on it?
Serial number q11030
Firewol 80
Firewol 80
vmartineau
My trainer s/n is very close. Q 09710 firmware 56. Are you 100% sure it's not upgradable?
It would be a nice christmas gift.
- grayhair@naver.com
- Contact:
I have an Elite Turbo Digital Qubo Wireless Firmware 80, can I update the firmware on it?
Serial number Q12326
Qubo Digital is upgradable from serial number 9784.
Arion Digital is upgradable from serial number 903.
@martineau,
I'm sorry... it is out by a nose.
Guys, contact the customer care for the complete upgrade procedure
@martineau,
