Firmware update 196
red.hell
Re: Firmware update 196
Postby red.hell » Tue Jan 18, 2022 6:32 pm
osa.gensobunya@gmail.com wrote:This firmware is so terrible.
After the update, My Suito is no longer work w/ ERG and resistance adjust.
wich type of connection? I had problem of connection drop with ant+ but works well with bluetooth
gen.t
Postby gen.t » Wed Jan 19, 2022 1:38 am
Both.
Zwift(ANT/BT) and e-mytraining(BT) level mode are can't adjust the resistance. I'm contacting Elite support.
gen.t
Postby gen.t » Wed Jan 19, 2022 1:47 pm
I contacted to Elite support, then they would like to suggest replacing my SUITO electric board. Maybe my issue isn't caused by the firmware.
Postby Elite Admin S » Wed Jan 19, 2022 3:28 pm
I'm sorry gen.
Please contact our support to understand what has gone wrong:
patbay64
Postby patbay64 » Sat Jan 22, 2022 11:07 am
bonjour
est il possible de revenir a l ancienne version depuis le telechargement les indications sur la plateforme kinomap ne fonctionnent plus
merci
vladimiro.mourato
Postby vladimiro.mourato » Wed Jan 26, 2022 11:17 am
Good morning,
Today during the firmware update for the 196, there was an error during the same and since then the trainer stopped communicating and it turns on (there was the sound turning on) but none of the leds is on and there is no communication. Has anyone had something similar happen? do you know how to restart the system?
Postby Elite Admin S » Mon Jan 31, 2022 2:26 pm
If something stop working during upgrado procedure, first of all try powering off the trainer and then powering it on again.
If this doesn't solve the problem, contact the customer care:
Return to “Suito”
