Request for power smoothing = 0
Re: Request for power smoothing = 0
it is impossible to use the super tuck position, you have to brake the flywheel with your foot otherwise there is always power.
steve.hammatt
Osso79 wrote:it is impossible to use the super tuck position, you have to brake the flywheel with your foot otherwise there is always power.
I've never had that problem with my Direto XR. Something is wrong there. Raise a support ticket with Elite so they can help you.
steve.hammatt wrote:Osso79 wrote:it is impossible to use the super tuck position, you have to brake the flywheel with your foot otherwise there is always power.
it is a known problem.
until the flywheel turns it calculates the power, even at 0 rpm.
I also tried with elite cadence kit with wire.
steve.hammatt
Osso79 wrote:it is a known problem.
There is soemthing wrong with your trainer or setup. The Direto XR does not usually work like that. Mine reports 0 watts after a few seconds after I stop pedalling, and then goes into supertuck (even though the flywheel is still spinning).
The known problem is that this few seconds delay is longer than that on some other trainers, which can be a disadvantage in Zwift racing for Direto users.
Any updates on this?
dorothyconnor
You can find new and trending outfits of winter season on our site. Which gives you a good and beautiful look in this season. You can find this NBA Charlotte Hornets Starter Jacket at a lower price than the market on our site.
