Elite Direto regulates resistance even if Erg mode is off in Zwift!
tanjaeric
Re: Elite Direto regulates resistance even if Erg mode is off in Zwift!
Postby tanjaeric » Wed Sep 29, 2021 10:16 pm
EmrickJack wrote:8-) Hello Everybody 8-)
maximilian.krause wrote:Hi Elite Support and others. Could that be causing the problem??
So I've been reading lots today on the Elite Direto. It seems that the flywheel magnets are what causes this issue. It is very sensitive to changes in cadence and the magnets shift to keep the flywheel spinning smoothly. This gives you that oscillating resistance feeling that you are describing. There's technically nothing wrong with the trainer, it's more of a matter of how to deal with it so that you feel it less.
Having a separate cadence sensor will improve your experience.
Keeping the flywheel speed up will decrease the oscillation resistance that you are feeling. Smooth cadence increases and power changes will probably work best.
Thanks Dear
Thank you friend.
Users browsing this forum: Bing [Bot] and 23 guests
