Hi there.
The offset sticker, on my Suito say 9617, but my latest calibration says 10025.
Witch effect will that have on my Suito?
No of the calibrations have been sub 10000.
What to do?
Best regards
Kent
Denmark
Suito calibration
Re: Suito calibration
With Suito it's quite normal to have this kind of difference. It's normal.
The firmware of the trainer will take into account the value to adjust properly the resistance and have a good accuracy
richard318
Hi, i just bought the Suito-T. I performed the calibration using the Elite app. I received an offset value of 9316. What does that mean? Is this good? Bad? Correct?
Thanks.
Thanks.
It's not good nor bad. It's simply a value that varies basing on the system friction (with system I mean rider + bike + trainer).
This value is used to adjust the trainer power map.
