Hello
I just recieved my new Direto and maybe I have two stupid questions:
1. No where in the documentation I found anything about something simple as Turn off, It says goes to "Sleep mode" but nothing else, is just a simple unplug from the electrical/enery wall plug?
2. How I can check that I have the latest version of firmware on my trainer?
J.
Elite Direto Firmware and Turn off
Re: Elite Direto Firmware and Turn off
Direto doesn't have a switch to turn it off. You can decide if wait the stand-by mode or unplug it (best solution to avoid storm damages).
About the firmware, by now there is only one firmware for Direto so... you have the last one!
By the way, in the future we will release an app that will check the firmware status of the trainer and eventually upgrade it.
Hello
Many thanks for the reply, actually I fond out that the Direto after a while of no use will shutdown itself. Also, thanks for the info about the firmware.
Now, I got another issue, I have my Garmin Edge 810 and I would like to pair manually the Direto since I got another Power meter next to it, where I can find this ID?
J.
J.
Hi J.
Garmin Edge 810 doesn't support the fe-c trainers. You can connect to it only as a speed&cadence sensor + power sensor.
I don't know if this is the information you need.
Hello
I found the ID for connecting manually to my Garmin 810, you need to take the cover of the leds and you'll dine the ID tag.
Thanks!
Thanks!
Users browsing this forum: Google [Bot] and 4 guests
