Can the Misuro B+ be used with the Arion Parabolic rollers to monitor speed, cadence and power?
Thinking of buying a Misuro B+ , have rollers already but want to be sure it will work before I buy
Robin
Misuro B+ and Arion Parabolic rollers
Re: Misuro B+ and Arion Parabolic rollers
Good morning
It depends on the version.
Check if there is the magnet housing on one side of the central roller (you should see the two screws that lock it).
If there is, it is misuro compatible
