Just came on board, so please bear with me if the question is strange.
I normally do all my workouts via Golden Cheetah or similar apps, connected via ANT+ FEC.
I was hoping to be able to connect myEtraining via Bluetooth and start the pedal analysis while I'm doing my workout.
But it seems that myEtrainging is eager to take over the erg control of the trainer. Making the training impossible.
Is there a possibility to use the myEtraining as a receiver of the broadcast from the trainer and the trainer is controlled via Golden Cheetha via ANT-FEC?
Or if there is another great workaround?
While I'm at it - is there any more knowledge base within Elite of how to analyze the data and to get a better pedal stroke?
thx
My E Training and pedal analysis while doing a workout on 3:rd party
peterliedholm
Re: My E Training and pedal analysis while doing a workout on 3:rd party
Pedal Analysis is a test that cannot be done while doing a training.
This because it needs to control resistance, so if you use other software in the meanwhile there will be conflicts.
About how to work with the data, you can read this document:
https://drive.google.com/file/d/0B2n_HS ... sp=sharing
