Ciao!
I've recently recovered an old Elite RealAxiom (wired, bought in 2006). I would like to know if I can use it's training function with the new app/software My E-training and use the dvds that came with it (Verona 2004 and Etape du Tour-Limoges) when I bought it, as far as I cannot get a proper computer for the old software.
Grazie tante!
Old RealAxiom
Re: Old RealAxiom
Ciao,
you can't use app My E- Training, Realaxion is not ant+ and doesn't have bluetooth. I have the same trainer and I'm using it with Real software on an old laptop with Windows 10, it's fine.
Here you can download the latest software version
http://tiny.cc/zpa9ny
If you need new videos I suggest this web site
https://www.bikelabshop.it/it/
Massimo
Massimo
Re: Old RealAxiom
maxdeep wrote:Ciao,
Massimo
One more thing. It works, but my laptop has no dvd unit. Is ther a solution?
Grazie tante!
Re: Old RealAxiom
I don't use DVD unit, I have all my races on an external hard disk ( 1Tb). You can chose the Directory for the videos in: settings - options - RealVideo
Re: Old RealAxiom
hola ya lo puedes usar ya que el programa my real video quedo obsoleto .
Re: Old RealAxiom
dear forum members can anyone help me with problems with my realaxiom wired trainer
Re: Old RealAxiom
Hi Sem
In this moment, my e-training Desktop software supports all the wired Real trainers.
Re: Old RealAxiom
Caro amministratore, che software è? Attualmente sto utilizzando la versione software realaxiom 5.0.0.25 basata su velotel
Re: Old RealAxiom
yeeess solved My E-Trainer works wired. thanks
