Elite Drivo-firmware update
Re: Elite Drivo-firmware update
So the Upgrado firmware app announcement showed up in my inbox. Downloaded and installed on an iPhone with the later version of iOS. Upgrado recognizes my 1st gen Drivo and says firmware (22) is up to date. First gen Drivo customers have been waiting for quite some time for firmware updates and it appears there is still no update in sight. What, Elite, are the firmware plans for the Elite Drivo 1st gen trainer?
Hi Elite
Is there a Drivo firmware upgrade available (for the Drivo II)? If so, will all users be provided with an email notification?
Thanks - Jim
Thanks - Jim
Yes, would be 8nteresing to receive an update that could solve the drop power issues!
rob959 wrote:So the Upgrado firmware app announcement showed up in my inbox. Downloaded and installed on an iPhone with the later version of iOS. Upgrado recognizes my 1st gen Drivo and says firmware (22) is up to date. First gen Drivo customers have been waiting for quite some time for firmware updates and it appears there is still no update in sight. What, Elite, are the firmware plans for the Elite Drivo 1st gen trainer?
I would like to know this as well. Would be great to have an update that speeds up the response to power changes in ERG mode.
I have a three year old Drivo trainer. Just tried the Upgrado app and the app reports firmware version 28. Is this the latest firmware version for the Drivo? When I ran the Upgrado app there was no report of any firmware being downloaded. The app just said "Connecting..." until I flipped the power switch on the Drivo off and on.
Thanks,
Thanks,
cheking mine says firmware 050, hardware 3, uptodate, about 1.5 years old, no problem so far
I've had my Drivo for about 6 weeks. Upgrado tells me it has Firmware 058, Hardware revision 8, and that it is up to date.
Mine says firmware 050, rev. 1
And also says that its up to date
Looks like this "upgrado" is pretty much useless
Seems that the only supported trainer (at the moment) is the Suito
https://www.elite-it.com/en/products/ap ... re/upgrado
For info just used the Upgrago app to check mine, Drivo Firmware 55 version 5
