No place for little magnet in my Arion Mag rollers?
Brandon
Postby Brandon » Fri Aug 10, 2018 4:31 am
I bought the Misuro B+ for my Arion Mag rollers, but I don't see a cover for a space to install the little magnet on the side of the roller.
Re: No place for little magnet in my Arion Mag rollers?
Postby Elite Admin S » Tue Aug 28, 2018 9:21 am
Not all the Arion Mag are misuro compatible.
You have to check if there's the magnet housing on the central drum (you should see the two screws that lock the housing)
If not, you need to buy the new central drum:
https://www.shopelite-it.com/en/spare-p ... mag-roller
nick n
Postby nick n » Wed Dec 12, 2018 11:17 pm
i just got the arion mag rollers too and I see that i have the magnet covering, but it almost seems like there is no magnet there? Where exactly should the misuro b+ sensor be positioned as I cant seem to find this information anywhere.
thanks
nick
andiyatsia
Postby andiyatsia » Mon Aug 05, 2019 4:22 pm
nick n wrote:Hi,
i just got the arion mag rollers too and I see that i Sarkari Result Pnr Status 192.168.l.l have the magnet covering, but it almost seems like there is no magnet there? Where exactly should the misuro b+ sensor be positioned as I cant seem to find this information anywhere.
thanks
nick
VYou have to check if there's the magnet housing on the central drum (you should see the two screws that lock the housing)
potagi
Postby potagi » Tue Oct 22, 2019 12:08 pm
The Misuro cannot be used with interactive trainers such as the Qubo Digital Smart B +. India news is already transmitted from the Saluti trainer card
icannell
Postby icannell » Fri Apr 24, 2020 3:31 pm
nick n wrote:Hi,
thanks
nick
Apologies for bumping an old thread - i've got the same problem as the person above. I have installed the magnet but there's no information on where the sensor should go - at a best guess i've put it on top of the frame next to the middle drum so the magnet goes right past it, is this correct?
Postby Elite Admin S » Fri May 15, 2020 12:07 pm
In the Misuro B+ user manual it's indicated also where the misuro must be placed, look towards the end of the document:
https://drive.google.com/open?id=0B_4_o ... 1Z3eFYwZmM
Return to “Misuro”
