I am using the old "Real E-motion"(not B+) for two years.
Until now, Zwift worked without any problems, but from July 17th, Wat output does not change at zero or constant.
May be related to the 16th day of zwift's automatic update.
It works without problems on "Software Real"(the output changes normally).
Aren't you anyone having the same problem?
The WAT output no longer changes on Zwift.
fredrik.blad
Re: The WAT output no longer changes on Zwift.
I have the same problem. Anyone know how to fix it?
