Connection to Bluetooth
Questions on how to use this forum
Wejustsurf
Postby Wejustsurf » Wed Jul 18, 2018 9:58 pm
Hi I have just got a Qubo power mag smart b+ And I can’t connect it to my e-training app. Could someone please help me? Do I need to get something to make the Bluetooth work? X
Re: Connection to Bluetooth
Postby Elite Admin S » Thu Jul 19, 2018 12:44 pm
Can you tell me which model of smartphone/tablet are you using?
Which error do you get in the app?
piermtb
Postby piermtb » Mon Dec 31, 2018 4:57 pm
Ho acquistato un dispositivo Digital smarth più
Ed ho riscontrato problemi con la connessione bluetooht anche avendo un Cell abbast aggiornato S 5
Devo acquistare una chiavetta Ant più anche per il cellulare
Aspetto vostre risposte ..
Auguri
jensy
Postby jensy » Tue Jul 02, 2019 3:16 pm
[quote="piermtb"]Ho acquistato un dispositivo Digital smarth più
Ed ho riscontrato problemi con la connessione bluetooht xender discord omegle anche avendo un Cell abbast aggiornato S 5
Nathan Luke
Contact:
Postby Nathan Luke » Mon Jul 08, 2019 5:02 am
:D Hello :D
To Connect windows 7
1 Click Start > Control Panel > Hardware and Sound > Device and Printers.
2 Under Device and Printers, click Add a device.
3 Make sure the Bluetooth headset has been set to Pairing Mode. In the Add a device window, select the Bluetooth headset, and a Connecting to device notification should occur.
4 Make note of the taskbar area as it will show Installing drivers and a notification that there is a Bluetooth device connecting to the laptop. Double-click the notification, then enter the paring code for the Bluetooth headset.
5 Once the correct code is entered there will be a notification that the Bluetooth is successfully paired with the laptop.
(Default paring codes are 0000 or 1234. If you are getting an error code, invalid paring code, check with the Bluetooth headset manufacturer).
6 Next, go to Control Panel and select Sound.
7 Select Speakers - Bluetooth Hands-free Audio, then select Set Default.
8 Close all previously opened media players, reopen the player, then select the music to listen to.
araeue@yopmail.com
Postby araeue@yopmail.com » Mon Jul 15, 2019 10:19 am
Bluetooth has some of the connection on this it was good to read all parts that was good among all of parts on this. You have to get some of the parts that was on expert writers uk this was the company that work at this city since long or have the all details on it that have all knowledge.
Return to “Forum questions”
