I normally use my Arion Digital Smart B+ rollers over ANT+. Yesterday I tried using them over Bluetooth (as I was testing Zwift on my Windows tablet and I couldn't charge it if I had an ANT+ dongle plugged in...) but the resistance control was apparently not working - the rollers were set to the lowest resistance all the time.
Is this as known issue? Is there a different firmware I could try? I could just get an OTG cable with a charging input but it would be easier to be able to use Bluetooth to control the resistance.
Also, as a side note, the power reading of the trainers is way off - much lower than when compared to a power meter reading. Is there anything that can be done about that?
Thanks!
Arion Digital Smart B+ control over Bluetooth doesn't work
Re: Arion Digital Smart B+ control over Bluetooth doesn't work
Please contact our customer care using the contact form in the app (in this way we'll received also some useful information on your device) and specifying the serial number of the trainer.
Hi, what app do you mean? myETraining?
Pete
Pete
Yes.
Run my e-training on your tablet, open the parameters menu, scroll down and you'll find a "contact us" option.
