Speed data readings from Elite Turno
johan.kjaer-hansen
Postby johan.kjaer-hansen » Wed Jan 16, 2019 4:52 pm
1) I am having some issues with the speed data that is transmitted by the Misuro b+ sensor on my Turno, which I track using my Garmin 920 (and 935).
I have configured the Misuro b+ sensor (15 blinks) and set correctly the wheel data on the Garmin.
The problem is that during power sprints and transitions using the gears on my bike, the speed data spikes hugely (> 200 km/h!) and rendering useless the average speed (typically >60/70 km/h) of my training sessions.
2) I have replaced the battery of the Misuro b+ sensor in early December 2018 and the battery is now January 2019 already low - is this normal under average usage?
Best regards,
Flash Gordon :)
johan.kjaer-hansen
Re: Speed data readings from Elite Turno
Postby johan.kjaer-hansen » Mon Feb 18, 2019 11:52 am
In the meanwhile... I have found a solution from one of the posts on the forum, outlining that when using non-Elite devices/apps, such as the Garmin 920 that I use, I have to change the Garmin settings and enter a circumference value equal to that of its wheel divided by 15.34 ;) .
This solved the problem. :D
fernandezdav
Postby fernandezdav » Mon Feb 18, 2019 12:03 pm
In my case, in garmin edge 100 >200km/h and in myETraining 16km/h, it's a joke
fernandezdav
Postby fernandezdav » Mon Feb 18, 2019 12:12 pm
Configuring Myetraining I didn't seen how to include enter a circumference value in myETraining maybe because I made it by my mobil phone?
Waid1P
Postby Waid1P » Tue Apr 30, 2019 1:56 pm
I was very excited to purchase the Elite Turbo Muin with Misuro B+ sensor. The sensor appears to pair but no speed or cadence reading
Return to “Turno”
