Drivo II - front wheel block needed?
scoob
Postby scoob » Wed Jan 30, 2019 11:47 am
Hi folks.
Does the Elite Drivo II need one of the front wheel supports to make the whole set up ‘level’?
I know the Neo did. It came with one and the front wheel rested on the block so was lifted a bit off the floor.
I can’t tell if the Drivo II set up means you are ‘level’ with or without a front wheel holder and can’t see anything that tells me.
I’d like to know one way or another if Elite (or anyone else) know the answer please?
Thanks.
sebrios
Re: Drivo II - front wheel block needed?
Postby sebrios » Wed Jan 30, 2019 1:26 pm
You dont need one ;)
scoob
Postby scoob » Wed Jan 30, 2019 7:36 pm
Fantastic - thanks v much for that !
Return to “Drivo & Drivo II”
Users browsing this forum: Bing [Bot] and 26 guests
