RealAxiom - No rider / no device connected
mrmahony86
Postby mrmahony86 » Sat Jan 26, 2019 10:48 pm
I usually used my wired RealAxiom trainer with my PC with Windows 7 installed on it but when I changed to a notebook with Windows 10, the software didn't work anymore.
There are different notifications that appear when I try to run a training programme, like "The device is not connected or not ready." or "No competitor selected! Please select a rider." How can I fix this issue?
sauve_casper
Re: RealAxiom - No rider / no device connected
Postby sauve_casper » Tue Mar 17, 2020 4:10 pm
hello, i have the same problem, did you find a solution.
thank you
mt.79
Postby mt.79 » Sat Mar 28, 2020 12:41 am
Buonasera, ho lo stesso problema. C'è qualcuno che ci riesce ad aiutare? Grazie mille.
maxdeep
Postby maxdeep » Wed Apr 01, 2020 9:23 pm
Ciao,
scarica l'ultima versione del software qui
http://tiny.cc/zpa9ny
Questo è il link per la corretta configurazione delle porte com:
https://elitesrl.zendesk.com/hc/it/arti ... rce=search
L'unica cosa che non funzionerà sono le web race dove non riesci a connetterti con i competitori... almeno per me e in Elite ancora non sono riusciti a risolvere. Lo sto usando con windos 10
Return to “Real trainers”
