I have the Elite Direto trainer, but i lost the thru axle acessory that works fine with my bike (Cervélo R5 Disc Etap).
Where i can find and buy a new acessory? I found the 12x148mm adaptor in on-line stores, but is not the same that come in Elite Direto, correct?
Thanks.
Regards,
Rui Alexandrino
Elite Direto 12x142mm
Re: Elite Direto 12x142mm
Please contact the customer care at real@elite-it.com adding a reference of the part (look at the user manual)
btw, if i have mtb with 12x142 qr thru-axle do i need some adapter with direto, or it already have all that need in box?
In your case, probably the power fluid is sufficient (indeed, you'll also need a sensor to make it smart).
happy wheels
happy wheels
