Invalid SN on new trainer
miveli
Postby miveli » Thu Jul 13, 2017 11:11 am
Hi Guys,
I have a new Turbo Muin Smart B+ trainer and when I go through the setup with the My E-training app the serial number is invalid according to the app.
Any ideas?
Mark
Re: Invalid SN on new trainer
Postby Elite Admin S » Thu Jul 13, 2017 11:25 am
Hi Mark
Which number are you trying to insert?
miveli
Postby miveli » Thu Jul 13, 2017 11:26 am
S/N 53558
Postby Elite Admin S » Thu Jul 13, 2017 11:39 am
Are you trying to put also the "S/N"? You have to insert only the number (53558)
miveli
Postby miveli » Thu Jul 13, 2017 12:02 pm
yeah I am only using the numbers.
miveli
Postby miveli » Thu Jul 13, 2017 12:09 pm
It looks like the QR code is wrong. i just tried a manual configuration and the S/N worked. I will try it again in the morning.
Postby Elite Admin S » Thu Jul 13, 2017 12:24 pm
Good!
I'll forward the information to our quality department.
miveli
Postby miveli » Fri Jul 14, 2017 9:30 am
Tried again this morning and using a manual configuration on a tablet and android phone, I was able to get data from the misuro. When doing the QR code, both devices failed at the serial number. Hope that this helps.
Cheers.
dwtrux@att.net
Postby dwtrux@att.net » Mon Jul 24, 2017 1:15 am
I had a similar problem with getting my Misuro B+ working with my Quick Motion Rollers a couple of months back. QR did not work but manual entry did.
Postby Elite Admin S » Mon Jul 24, 2017 9:10 am
Thank you guys, we'll do some check on the QR code labels
