Muin B+ seeing other speed sensor?
steve.allington
Postby steve.allington » Wed Oct 10, 2018 8:30 pm
After working fine for a number of months I am currently having issues with my trainer not seeing the correct speed sensor. It is seeing a praxis works speed sensor ?
Also should I be seeing the misuro B as the sensor or the elite trainer - this is both in the power meter sensor and speed ?
Steve
Re: Muin B+ seeing other speed sensor?
Postby Elite Admin S » Thu Oct 11, 2018 9:29 am
Hi Steve
Our application can connect to every ant+ fe-c or bluetooth LE sensor, so... it is possible that you've paired with the wrong sensor.
Please do again the configuration and when the app looks for the sensors wait until you see both the sensor in the list.
If you cannot see the misuro B+, check the battery level ;)
If you still cannot find it, let me know.
steve.allington
Postby steve.allington » Thu Oct 11, 2018 7:41 pm
OK I appreciate it may pick up other sensors but I don't own another sensor so not sure why it is picking up the praxis. Misuro B+ is not shown or found in either field but elite trainer is in power source. So i can ride paired with elite trainer for power and praxis for cadence
Should I change battery ?
steve.allington
Postby steve.allington » Fri Oct 12, 2018 9:07 pm
Tried replacing battery and reinstalling app but still showing elite trainer 17894 in power meter and praxis works speed/cadence 17894.....misuro B not findable.
I am not overly fussed as long as these sensors are giving true readings.......but can't work out why praxisworks when I don't own such a sensor and hence nowhere near turbo
Postby Elite Admin S » Thu Oct 18, 2018 12:35 pm
I see that you have already contacted our customer care service.
Please go on with the assistance there and at the end you can share here your experience.
divop
Postby divop » Sun May 26, 2019 12:51 pm
You have to see the all other speed sensor that was about the all friction that was available on this article. if you have to get the all frictions on this you have to check grademiners among the all details on this that was good and useful on this.
Return to “Turbo Muin”
