Hi - is the Digital Qubo Wireless compatible with the Garmin 520?
Thanks.
Digital Qubo Wireless and Garmin 520
Re: Digital Qubo Wireless and Garmin 520
The Qubo Digital Wireless it's not compatible with Garmin 520.
But, if it is the upgradable version, you can do the upgrade to fe-c and then connect with it.
Can you tell me the serial number of your trainer?
Hi - it's Q14239.
Thanks!
Thanks!
I confirm that it is upgradable. After the upgrade, you'll be able to connect it with the garmin.
Please notice that:
- to upgrade the trainer, you need a pc and a ant+ dongle
- after the upgrade, you won't be able to connect the handlebar console anymore
- after the upgrade, the trainer will be fe-c compatible so if you use the my e-training app you have to select "qubo digital interactive"
If you decide to do the upgrade let me know, we'll send you the instructions on your forum email address
Please notice that:
Yes please - send the instructions
Thanks!
Thanks!
Sorry, we have some problems sending you the instructions to your forum account address.
Please write me a pm with a different email address
I've just sent a PM.
The message has appeared in my Outbox - have you received it?
Received!
We're going to send you the instructions
Hi - please can someone contact me. The instructions sent didn't work. I get "Upgrade not possible" error.
Please contact our customer care and add the log report of the upgrade procedure.
Users browsing this forum: Bing [Bot] and 6 guests
