Drivo Bluetooth Connection
loki
Postby loki » Tue Jul 11, 2017 12:16 pm
how can i connect the drivo via bluetooth to zwift?
i can see a DR in the bt enviroment on my phone but it does not allow a connection ?!
Re: Drivo Bluetooth Connection
Postby Elite Admin S » Tue Jul 11, 2017 12:22 pm
Simply run Zwift, select controllable trainer and then choose fe-c trainer in the list of available trainers.
If it doesn't work, please let me know the status of the Drivo leds.
loki
Postby loki » Tue Jul 11, 2017 12:24 pm
ant and bt leds are broken.
so i dont need to connect the drivo via bluetooth .. pairing it to my phone ... before zwift can use it?
Postby Elite Admin S » Tue Jul 11, 2017 12:59 pm
About the leds, I suggest you to contact our customer care at real@elite-it.com to ask for a repair.
The status of the led is important to check the trainer behavior.
About the connection, I confirm you that you do not need to connect it to the phone. Run the app and let me know if all works ;)
flimps
Postby flimps » Thu Jan 02, 2020 8:15 pm
Return to “Drivo & Drivo II”
