Bonjour
Comment faire pour télécharger des vidéos ?
Matériel : Qubo Digital Smart B+
Merci
Téléchargement de vidéo
Re: Téléchargement de vidéo
Do you mean our Elite RealVideos or the free myRealVideos?
In the first case, by now it's only possible to buy them in a shop (in the near future we will also have an online purchase).
In the second case, you can simply select myRealVideo and choose between the available videos.
Oui mais comment faire pour Myréalevideo.
Il faut être connecté sur ID real sur le logiciel REAL ?
cordialement
cordialement
I confirm you that you have to be logged in.
After the login, select myRealVideo in the menu bar.
Hi, is it possible to download video in ICloud either from my realvideo or realvideo to save storage on iPad and share video with my wife which has own myetraining account ? Best regards. Philippe
I'm sorry it is not possible
