info modello drivo
lellinoaereoplanino
info modello drivo
Postby lellinoaereoplanino » Thu Jun 21, 2018 1:29 pm
salve
sono possessore di un drivo
come posso fare a capire se è l 'ultimo modello ( dichiarato 2018 da molti siti che lo vendono )
oppure il primo/precedente?
dal seriale? da qualche caratteristica estetica?
grazie
chrisper
Re: info modello drivo
Postby chrisper » Fri Jun 22, 2018 4:26 pm
Old Drivo: Image
New Drivo: Image
The hole behind the freewheel is bigger.
sebrios
Postby sebrios » Fri Jun 22, 2018 8:43 pm
What are the differences between those 2? I mean, operational differences..
Is it worth upgrading from the old one to the new model? or is it just esthetical
(Besides the new firmware ofcourse, because I believe the old one will get the upgrade soon...)
Postby Elite Admin S » Mon Jun 25, 2018 12:02 pm
The two versions are identical.
The only modify we have done is, indeed, the enlargement of the hole over the flywheel.
It has been done only to ease the production, it doesn't affect the functionality of the trainer.
lellinoaereoplanino
Postby lellinoaereoplanino » Mon Jun 25, 2018 1:15 pm
si legge in giro che il vecchio abbia un volano da 5.1 kg mentre il nuovo da 6.0 kg
tutto falso?
Postby Elite Admin S » Tue Jun 26, 2018 9:20 am
Confermo che il Drivo è sempre stato prodotto con lo stesso volano da 6kg.
lellinoaereoplanino
Postby lellinoaereoplanino » Tue Jun 26, 2018 11:23 am
grazie
Return to “Drivo & Drivo II”
