CONCONI TEST
mabruk66
CONCONI TEST
Postby mabruk66 » Fri Jun 23, 2017 11:39 am
I purchased an Elite Drivo. I'm using myEtraining app but I can't find "Conconi Test" anywhere.
I loaded the real software and it's not there either.
Can anyone explain where is "Conconi Test" located?
Re: CONCONI TEST
Postby Elite Admin S » Fri Jun 23, 2017 11:47 am
I'm sorry, the Conconi test is no more available in our software and app because our license has expired, so we don't have the permission to use it anymore.
mabruk66
Re: CONCONI TEST
Postby mabruk66 » Fri Jun 23, 2017 11:52 am
Ok. than what should I use for testing my fitness level in your app?
Is it the "Training Test" section or do you have anything else?
Re: CONCONI TEST
Postby Elite Admin S » Fri Jun 23, 2017 12:19 pm
You can use the training test. By now, we don't have any other test similar to Conconi test.
Talking about tests, you can also evaluate the purchase of the pedaling analysis (http://drivo.cc/system/cms/document/dat ... sis_02.pdf)
Finally, you can look if there is any other third party app which is compatible with ant+ fe-c trainers that has fitness tests.
mabruk66
Re: CONCONI TEST
Postby mabruk66 » Fri Jun 23, 2017 12:21 pm
Thanks for the fast reply.
Regards.
roka9160
Re: CONCONI TEST
Postby roka9160 » Sat Oct 28, 2017 1:51 am
I bought a Kura 2 weeks ago, because in many german shops they offer it with the my e training app, including the conconi test.
Maybe I send the trainer back, because the heartrate by bluetooth doesent work with my Ipone too.
I am disappointed
Re: CONCONI TEST
Postby Elite Admin S » Tue Oct 31, 2017 12:39 pm
I confirm that the Conconi is no more present in the app (only the Training Test).
If you cannot connect the heart rate transmitter to your phone, the trainer cannot be the cause (the transmitter communicate directly with the app).
Are you sure your heart rate belt is bluetooth smart? Did you check the battery level?
Also, try restarting the phone, remove and put again the battery in the belt, run the app and pair again the belt from the advanced settings menu.
