cleaning the rollers on Quick Motion
dwtrux@att.net
Postby dwtrux@att.net » Fri Apr 27, 2018 2:56 pm
Any tricks for safely cleaning the tire black off of the plastic rollers? Or do you leave the tire black as a badge of effort?
Re: cleaning the rollers on Quick Motion
Postby Elite Admin S » Wed May 02, 2018 9:08 am
To clean it, use simply some alcohol.
We suggest to use slick and hard tires to minimize the consumption ;)
dwtrux@att.net
Postby dwtrux@att.net » Wed May 02, 2018 3:03 pm
Scotch or Bourbon?
Thanks.
Postby Elite Admin S » Thu May 03, 2018 8:31 am
Grappa of course, Elite is an italian manufacturer :lol:
Kidding, of course I meant denaturated alchool
dwtrux@att.net
Postby dwtrux@att.net » Thu May 03, 2018 3:29 pm
Of course grappa!
Tried the alcohol but really doesn't remove the dark smudge. Tires are old Bontrager road tires. I think the smudges are when I roll to the edge on the front roller and the back tire slips in the rollers. Not often but enough in any one ride.
Guess with over 1400 miles on trainer, it is expected to show this badge.
Postby Elite Admin S » Fri May 04, 2018 8:45 am
Not good. Probably, you should have cleaned it after every ride.
Well, as you told before.... badge of effort! :mrgreen:
jvanas776
Postby jvanas776 » Tue Jun 04, 2019 2:34 pm
I also have a problem with the black building ono the roller surface.
I am using a trainer tyre though, which is supposed to have a harder compund. The black on the roller is creating an artificial surface. How do I clean it off?
Surely there has to be a way.
Return to “Other Trainers”
