No speed data with Trainer Road
I have Misuro b+ sensor in mode 5 with Qubo Power Fluid trainer, but there's no speed data for Trainer Road? With myEtraining app there's speed data, but that's probably calculated from cadence and power?
Re: No speed data with Trainer Road
I suggest you to contact directly trainerRoad about this issue.
regards
regards
etienne.massal
Just for your information, I have the same problem with my turbo muin and trainerroad: power and cadence but no speed...
Regards.
Regards.
I asked Trainer Road about this and will post their answer/solution here for future reference.
