Is mine Upgradable?
SN Q 13539?
Digital Qubo Wireless
Re: Digital Qubo Wireless
Hi s/n Q11097. Is this an upgradable firmware version?
Is mine Upgradable?
Q 13521
Q 13521
My Qubo s/n is Q1803.
Is that upgradable?!
maciejaszek,
lime2269
guys, your trainers areupgradables.
coolalex1227,
I'm sorry yours is not.
lime2269
coolalex1227,
I have a Qubo Digital Wirelless ANT + trainer .Product number: Q12346.It is possible to upgrade the software or not.Trainer is incompatible with Rouvy, Zwift and others.If yes how should I proceed?Thank you for help.
Best regards
Stanislav Fongus
Best regards
Stanislav Fongus
Yes, it is upgradable.
Contact the customer care at real@elite-it.com specifying the serial number, they'll give you the complete instructions.
I have a Qubo Digital Wirelless .Product number: Q.12478. It is possible to upgrade the software?
Thanks in advance.
Thanks in advance.
@kalkasistem,
I confirm you that it is upgradable.
Contact the customer care at real@elite-it.com and ask for the complete instructions.
