Problema Elite Avanti Cambio Virtuale Cog
AldoSpaziale
Postby AldoSpaziale » Thu Oct 09, 2025 7:18 am
Buongiorno, ho acquisto elite avanti e successivamente il cog + clickv2 per utilizzarlo con zwift
Una volta montato il cog come da istruzioni.
Ho utilizzato l'app my training per configurare la rete WiFi e con upgrado scaricare l'ultimo firmware indicato come 36
Aprendo zwift mi collega Avanti come Power Resistenza Cadenza con segnale WiFi e i Clickv2 con segnale Bluetooth.
Una volta collegato tutto non mi riconosce il mio Smart Trainer come supportato per la cambiata virtuale.
Non so come risolvere, qualcuno ha questo problema?
william.davey8
Re: Problema Elite Avanti Cambio Virtuale Cog
Postby william.davey8 » Sat Oct 18, 2025 7:29 pm
I do not have quite the same problem, my problem is that I connected the Avanti trainer to the internet to update the firmware to version 36. When I then tried to run an exercise with my Windows laptop I got a message from MyEtraining saying "no incoming data" and then the app switched back to the start window. After trying various devices and switching different features on and off, I found the correct solution was to cut the internet connection. Then the app and trainer worked as expected. Try this work around and see if it works for you.
tonyadams
Postby tonyadams » Sat Apr 04, 2026 8:15 am
Collega l’Elite Avanti Smart Trainer via Bluetooth (non WiFi) in Zwift. Se non va, la combo con Elite Cog + Click v2 non è ancora supportata.
Cool Games
lunadam
Postby lunadam » Tue Jul 07, 2026 9:22 am
I was trying to connect both over Wi-Fi and Bluetooth, so that probably explains why it wasn't working. I'll switch the Avanti to Bluetooth only in Aquapark io Zwift and give it another try. Hopefully Elite adds full Cog + Click v2 support in a future update.
