Resistance Issue with Elite Direto XRT and Garmin Forerunner 955 When Using Humango App
celik.ozuduru
Postby celik.ozuduru » Fri Feb 07, 2025 8:41 am
I have been using the Elite Direto XRT indoor interactive trainer and training with the Humango app. All scheduled workouts are automatically uploaded to my Garmin Forerunner 955 watch. Initially, I had no issues completing my bike sessions with my watch connected to the trainer. However, recently, as soon as I launch a scheduled training session from my watch, the resistance immediately maxes out, making it impossible to pedal. If I manually adjust the resistance and/or gradient from my watch, it disrupts the structured workout. Interestingly, when I launch a Garmin-generated bike training, everything works fine. Does anyone know what might be causing this issue?
Note: Both my Forerunner 955 and Elite Direto XRT firmware are up to date.
3willy_it
Re: Resistance Issue with Elite Direto XRT and Garmin Forerunner 955 When Using Humango App
Postby 3willy_it » Fri Feb 07, 2025 5:30 pm
Hi there, same trainer, same watch and same problems...I changed something inside the MyEtraining app, and now, when I'm in a workout, the trainer randomly disconnects from my Garmin, lowering the resistance to 0. After 20 or 30 seconds, it restarts working correctly... Any ideas?
celik.ozuduru
Postby celik.ozuduru » Wed Feb 12, 2025 11:51 am
That issue also happened last week, in the middle of the training session, resistance suddenly dropped along with the power. it is really annoying since that I have been trying to fix this issue for a long time.
florencepugh
Postby florencepugh » Thu Aug 28, 2025 7:05 am
You should disable "use trainer control" on the watch and let Humango push the workout directly to the Direto XRT Pips NYT, or re-export the workout in a Garmin-compatible format to avoid the max resistance spike.
Users browsing this forum: No registered users and 37 guests
