Trainer was fine yesterday, and when I jumped on to do a workout today, the resistance isn't consistent. I've had the wading through mud high resistance issue in the past, but this is different.
I've been looking to see if there's any advice on resetting or upgrading firmware, and can't find anything.
Will send a message to the support team but I know that always takes days to get any kind of response...
Any thoughts / guidance appreciated.
Inconsistent resistance on Direto XR
Re: Inconsistent resistance on Direto XR
Hi Jonathan
Is it possible that you've paired the trainer to two different devices? Do you perhaps have some applications still active in the background?
This would explain the inconsisten resistance value.
This post has more than two years but i wonder if you can solve this problem???
I have the same feeling last weeks with my Direto. The resistance is not consistent, one pedal round hard, next round soft....
I´v tested with different trainer software and the problem is same in every them.
Example; I biking on zwift and when the climb comes Direto can´t simulate in a constant way.
One pedal round hard and the next round soft, and so everytime.... It´s very disgussting.
Any idea to solve it?
Users browsing this forum: No registered users and 37 guests
