Elite Suito vibration - larger and smaller gears.
Mazzletov
Postby Mazzletov » Fri Apr 22, 2022 3:44 pm
Hello
I bought a Elite Suito-T for my 29" Mountainbike. Whem the chain is in the middle of the cassette, everything works fine. When I shift the chain to the largest gear, ( not necessarily the last blade), I get a lot of vibrations. The same happens when I shift to chain to the smallest gear on my cassette.
I have 10 gears. On 4,5 and 6 everything is smooth. When I go to gear 2, 3 or 7, 8 I get vibrations. When I go to 1 or 9 there is a lot of vibrations.
I have the trainer for 2-3 months, +- 200 km on it so brand new.
Re: Elite Suito vibration - larger and smaller gears.
Postby Elite Admin S » Wed Apr 27, 2022 9:44 am
It may be necessary a fine tuning of the gear.
Did you add one spacer as indicated in the user manual?
Return to “Suito”
