Question Suito T
sla.gilles
Question Suito T
Postby sla.gilles » Wed Mar 30, 2022 11:43 am
I'm using the Elite Suito T for 3 months now. I'm relatively satisfied.
I use it with my mountain bike canyon spectral 2020, with the boost 12x148 adapters. Most of the time I'm using zwift.
I've questions.
1. When I put the bike on the home trainer I have to fine tune the rear shifter and vice versa when I put back the bike on wheel. Is it normal?
Are you in the same situation?
2. Often I can hear from the trainer a kind of "toc" from inside. I don't know what it is, any idea?
3. Sometimes a sound like a bike bell is coming from the trainer, any idea?
Thanks fro your support and your feedback,
Gilles
Re: Question Suito T
Postby Elite Admin S » Thu Mar 31, 2022 8:45 am
Hi Gilles
Which cassette are you using? How many spacers have you used?
Hard to say without hearing the noise. I suggest you to record a video and send it to our support
I think you're hearing the motor adjusting the resistance
Return to “Smart Trainers”
