Hello all,
I just obtained a used Turbo Muin direct drive trainer and Misuro Blu sensor. I would like to use it with Zwift, but I've not had success getting it set up. Has anyone had success with this?
I read on Zwift that Turbo Muin needs Misuro B+ to operate with Zwift https://support.zwift.com/en_us/direct- ... 2meS#Elite
A few quick questions:
- does anyone have experience with Turbo Muin and Misuro B+ and Zwift?
- where can I find a Misuro B+ ?
- where can I find instructions for using Misuro B+ with Turbo Muin?
Turbo Muin with Zwift
cmbevilacqua
-chris / cmbevilacqua
"ride, Forest, ride!"
Re: Turbo Muin with Zwift
About Misuro B+, I confirm you that it is compatible with Zwift.
You can find it here:
https://www.shopelite-it.com/en/sensors ... o-b-sensor
About Misuro Blu... it should be compatible with Zwift, but some attentions are required.
Check again the configuration on Zwift (part on speed&cadence settings):
https://elitesrl.zendesk.com/hc/en-us/a ... n-on-Zwift
Check also the position of the misuro blu on the trainer:
https://www.youtube.com/watch?v=a69xJnz ... E&index=21
Finally, try replacing the battery
If you still have problems, contact our support:
cmbevilacqua
Thank you, I will try out the things you mentioned with the Blu sensor
cmbevilacqua
I ordered a Misuro B+ and got it working with Zwift, thanks for all the help!
