Vote BLE Dropouts with Elite Justo 2 + Zwift Ride Smart Frame
Posted: Fri Nov 07, 2025 11:30 am
by nenadjev
Hi everyone,
I’m experiencing persistent Bluetooth dropouts between my Elite Justo 2 trainer (firmware v36) and Zwift when used with the Zwift Ride Smart Frame in virtual shifting mode.
Setup details:
• Zwift Ride Smart Frame + Zwift Cog
• Elite Justo 2 trainer (firmware v36)
• Windows 11 Pro (ThinkPad X13, Intel AX201 Bluetooth 5.1)
• Android 16 (Samsung Galaxy S25 Ultra, Zwift Companion)
• Tested both direct Bluetooth and Companion bridging
Issue:
• Initial pairing works perfectly
• During rides, Zwift intermittently loses connection to Justo 2
• Zwift Ride Handlebars and HRM stay connected without issue
• To restore functionality, I have to manually re-pair Justo 2 via the ‘Paired Devices’ screen
• Dropouts are less frequent with Companion bridging, but still occur
What I’ve tried:
• Uninstalled/reinstalled Bluetooth drivers
• Removed all paired devices from Windows
• Clean reinstall of Zwift (including Documents, Program Files, AppData)
• Reset Zwift game preferences (Zwift Support Guide)
• Ensured Justo 2 is not paired via Windows Bluetooth settings
• Verified admin privileges and system-level permissions,
• Disabled the internal Bluetooth adapter and tested with an external USB Bluetooth dongle with a USB extension cable to position the dongle closer to the trainer and away from potential interference sources.
etc…
Last winter, everything worked flawlessly with Justo 2 + standard bike, but I didn’t use the trainer from May to October, and the issue started after switching to Zwift Ride and updating to latest firmware
Zwift Tier 3 support confirmed a Windows-level GATT failure, but no clear root cause
I’ve also contacted Elite support, but unfortunately their response was limited to basic troubleshooting questions and didn’t offer any meaningful insight or escalation. At this point, I’m stuck between two support teams and still without a stable solution.
Has anyone else experienced similar BLE instability with Zwift Ride + Justo 2? Any insights, workarounds, or firmware rollback options would be greatly appreciated
Thanks in advance,
Ned
Re: Vote BLE Dropouts with Elite Justo 2 + Zwift Ride Smart Frame
Posted: Mon Feb 02, 2026 10:17 am
by lisamassa
Sorry to hear about your Bluetooth issues with the Elite Justo 2 and Zwift Ride. It sounds frustrating, especially after trying so many fixes. Have you checked for any nearby devices that might cause interference? Also, testing with another device could help narrow down the problem.
bat smash game
Posted: Sat Apr 18, 2026 1:14 am
by out.riding
Geez if only there was some way to avoid this Bluetooth connection problem like Dircon or WiFi. Of course I am being sarcastic. I am angry after paying hundreds extra for the Justo 2 with WIFI and buying the Dircon adapter to find Elite does not support "Bluetooth over WiFi/ethernet" for resistance with Virtual Shifting like other brands do. Elite supports "Bluetooth over Wifi/ethernet" for power, cadence, and heart rate (although Justo 2 won't pair with CORE). Why doesn't this supposed premium product support what Wahoo and other brands do?
Until this is corrected I will continue telling people to avoid Elite products. My experience with the Justo 2 lacking this basic feature and my Aria both becoming unresponsive between uses AND suddenly going to full speed after the ride during cooldown has not been "Elite".
Posted: Mon Jul 27, 2026 10:54 am
by ladyjames6600
Thank you for sharing!
Posted: Thu Jul 30, 2026 4:15 am
by xeniae
FNAF Game
Until either Elite or Zwift releases a firmware or software fix, the only realistic workarounds are using Companion bridging (if it reduces the frequency of dropouts), trying an ANT+ connection (if supported), or rolling back to an earlier trainer firmware if Elite provides that option.
