Disapointed - Upgrado App Doesnt Find Trainer
s.pidduck
Postby s.pidduck » Fri Dec 22, 2023 7:27 pm
The upgrado app doesnt find the JUSTO
It DOES find the RIZER
The trainer does pair with Zwift using the gateway so it feels like its all working.
BUT how do i check the firmaware if the upgrado app doesnt find it?
Just to say - the upgrado app finds the rizer
The rizer pairs with the Justo
I dont get it!
Help please
Thank You
s.pidduck
Re: Disapointed - Upgrado App Doesnt Find Trainer
Postby s.pidduck » Sat Dec 23, 2023 10:28 am
To everyone that reads this
MAKE SURE THE GATEWAY IS UNPLUGGED
Then it worked
Nowhere does it say this but i wondered and tried it
Boom it connected and upgraded as expected
A lot of angst
Elite I would suggest putting a prompt in the APP
It wont be common sense to everyone
Cheers
Return to “Justo”
