Video search by Country
The filter options allow searching on From and To. But these are just whatever the crerator typed in so often it is hard to find videos from a specific part of the world. In the videos database the Country is one of the columns also entered by the creator but that would be easier to search on than From and To. Ideally, part of the upload would automatically set the country based on the first data point in the GPS track so country was always available and accurate but searching on the creator's input is an easy first step.
Re: Video search by Country
Thank you for your suggestion, I'll forward it to the developers
