Hi All
I've got a Zumo just out of warranty (firmware is 191 HW revision is 003)
last nigh during a ride using MyEtraining (version 1.16.2 windows 10) , data stopped being sent to the app from the trainer...
the timer carried on advancing... the program hadn't frozen... but all the number went to zero. the ant connect was still good ie solid green light on the trainer and green bike shown on the home screen
I rebooted everything and the same symptoms ie good ant connection, but no data sent from the trainer
I loaded goldern cheetah and zwift... a good connection was made to these apps using ant, but no data being sent from the trainer
i loaded MyEtraining on an android tablet with a good Bluetooth connection. same results... no data sent from the trainer to the tablet
any help greatly appreciated
Steve
No data being sent
Re: No data being sent
In this case, it's necessary to contact our customer care:
The guys there will ask you some specific test.
Remember to specify the trainer model and its serial number
Ok thanks for the heads up
