I'm very unpleased since few days with my suito-t trainer
https://www.youtube.com/watch?v=abYYvG_8HS0
Tell me, have you ever came across this sound in your trainer? @ 00:03 sec.
Some kind of mettalic ringbell. It happens when spinning at higher power resistance, around 3W/kg and more and very often after finished training session. How do i get rid off this "ring" sound? It's driving me nuts.
Very annoying sound while peddaling and in rest mode
Re: Very annoying sound while peddaling and in rest mode
I've got the exact same issue on my Suito.
I've contacted Elite and have received the following response.
Unfortunately, it is driving me nuts as well. So if anybody has a solution, please let us know!
The "ping/bell" sound is not related to the resistance issue and is not a sign of a trainer malfunction. I confirm also that this sound doesn't affect in any way the performance and the functionalities of the trainer.
It is a normal sound that the trainer makes when in use (normally it happens when the trainer warms up).
As reported, other Suito make this kind of sound and can be used without any problems.
