I have a left-crank only 4iiii Precision power meter.
In all of the ANT/BT enabled devices (Garmin FR945/Zwift on my laptop/Garmin Edge) I can use it also as a cadence sensor.
When I look for it through the myETraining app - it doesn't appear (and I need to use my old Garmin cadence sensor).
I try to look for it both through ANT+ (I have a dongle connected to the phone) and BT.
Why is that?
Can you help?
Thanks,
David.
Suito-T - Configuring power meter as cadance sensor
Re: Suito-T - Configuring power meter as cadance sensor
It depends on how it transmits. Not all the power meters can be paired as cadence sensors.
I suggest you to contact the customer care:
