Where we can find the changes for this release of the firmware ?
Upgrado said nothing about the changes.
It will be interesting to know that !
Thank !
Firmware update 196
Re: Firmware update 196
i'm interested too, i'm using the original 191 rev 4, never updated
for me the only leak is the difficulty to make the calibration, it fails lot of times
Version 196 enable the incline parameter, which is used by Rizer accessory
ok, not necessary
but I hope in past releases that improve the calibration method, tried 3 time this afternoon after workout and fails 3 times
Hi red.hell
usually this kind of problem is caused by bad communication.
If you use a different device, do you have the same issue?
Try also by powering off all the wireless devices in the area.
If the problem persists, contact our support:
Elite Admin S wrote:Hi red.hell
thanks admin for the answer
normally i try with the smartphone but with the pc on, and router quite close
i have to try again with the pc only, trying to switch off the smartphone
I want to try a firmware update, but after next week, I have to train a bit for the last race of the season on monday 1st of november
tried again today but failed again, from pc, swich off wifi and bt, smartphone in airplane mode, garmin off
start the calibration after 1h workout, increase speed up to 50 km/h but don't show the target speed
I see in smartphone a log created, but pc app seems don't save a log
yesterday I've finally completed a calibration
pc and garmin off, smartphone just rebooted and trainer connected with bluetooth, 3 min of warmup -ok, less than suggested, but it's only a matter of final result- and than calibration, first time failed, second time seen "increase speed", no target speed shown and than ask me to stop pedaling
i get a value close to 9800 ms, more or less, if i remember correctly, of last time in March
This firmware is so terrible.
After the update, My Suito is no longer work w/ ERG and resistance adjust.
Users browsing this forum: Bing [Bot] and 8 guests
