Suito-T Legs to tight
mjv144
Postby mjv144 » Fri Sep 17, 2021 4:32 pm
Is there a way to loosen the Suito's legs. I am able to fold them open and closed but have to use considerable force. The left leg feels right but the right leg is much tighter. Not sure if the bolts on the bottom can be loosened but don't want to try anything until I get a confirmation from the experts.
Thanks!
Re: Suito-T Legs to tight
Postby Elite Admin S » Mon Sep 20, 2021 8:15 am
Don't loose the bolts, as the legs must NOT be loose, the risk is to compromise the stability of the trainer.
It's normal that you have to apply some force.
mjv144
Postby mjv144 » Mon Sep 20, 2021 8:14 pm
OK thanks but the right leg seems to get tighter the more I use it. Is this normal?
Postby Elite Admin S » Tue Sep 21, 2021 8:51 am
I've talked with our mechanics.
If the difference is too much, it's possible to work on the nuts that block the legs.
Here's some instructions:
Remove the plastic of the Suito like the image below:
Then, with a 17mm wrench, hold the nut that fix the leg (inside the Suito) and with a 7mm alley key fix/loosen the leg (outside the Suito) like in the images below:
Return to “Suito”
