Spacer with PG1230
Spacer with PG1230
I installed a PG1230 on my Suito and there is a lot of play. This cassette fits fine on my shimano freehub wheels, is a spacer required on my trainer and if so will the included ones suffice and how many?
Re: Spacer with PG1230
Usually with a 12sp cassette no spacers are needed (there are some exceptions, though).
Check with your trusted mechanic or send us a video in which we can see the play and how the cassette is mounted:
spacer is needed, the couple of spacers, because it's an mtb cassette, that fits on 10v freehubs, and the installed one is an 11v road freehub
