Bluetooth is unstable and never worked right with Zwift
DDmors
Postby DDmors » Thu Jan 07, 2021 3:08 am
Bluetooth is unstable and never worked right with Zwift.
I have converted to Ant+ and fixed it as another persons has done in the form (http://forum.elite-it.com/viewtopic.php?f=48&t=2547 ). I think there is another underlying issues that needs to be resolved.
I have ruled out any Bluetooth or PC issues by testing with my wife's Trek trainer and that works perfectly with Bluetooth with the vary same setup.
Anyone what any suggestions?
alexmj
Re: Bluetooth is unstable and never worked right with Zwift
Postby alexmj » Tue Jan 12, 2021 1:51 am
I had this issue using my laptop from 2016, connection would drop intermittently and ERG mode kicked in very slowly. Switched to the Zwift app on my phone (2018) and it works a lot better. Maybe worth a shot.
DDmors
Postby DDmors » Mon Jan 25, 2021 5:22 pm
Thank you for the suggestion. This is not really a solution but a workaround. Still Bluetooth this way doesn't work properly
Return to “Suito”
Users browsing this forum: No registered users and 45 guests
