Slipping feeling on steep climbs
kngeerts
Postby kngeerts » Tue Jan 05, 2021 9:13 pm
When I'm climbing in Zwift on a steep hill (9%+) in a small gear (34x28) I get the feeling that something is slipping when I put power on the pedals. Fees like the belt is slipping inside of the trainer.
Is this something which is possible or can happen?
It's only happening on very steep hills and low gear. The issue makes climbing a virtual hill impossible.
mjv144
Re: Slipping feeling on steep climbs
Postby mjv144 » Thu Sep 09, 2021 11:21 pm
I have the same problems. Have you found a resolution on your own?
Postby Elite Admin S » Fri Sep 10, 2021 8:17 am
If you have slipping feelings, the best thing to do is:
- run the calibration
- contact our customer care specifying the serial number of the trainer and the value you get at the end of calibration
grsams74
Postby grsams74 » Sat Jan 01, 2022 1:40 am
Hi everyone,
I'm having the same issue. No problems for about a year but the last couple of months it has been getting worse. I've sent in a ticket, any news on the fix in the meantime?
Thanks and Happy New Year!
Return to “Suito”
