I have the problem of the power fluctuation using the erg mode with zwift. I saw that setting the power smoothing to a higher value could help. However I'm unable to see this parameter in the settings on both the android and apple apps. How do I do that?
Power smoothing setting not found in my e training app
louisduvergern
Re: Power smoothing setting not found in my e training app
Power smoothing is an option available only on the trainers that have an internal power sensor (Direto, Drivo...)
So, it's not available on Suito.
That said, power oscillations of around +/-20W are normal (they depends on the natural difference of power between a pedal stroke and another).
Do you have higher oscillations?
