Bluetooth is unstable and never worked right with Zwift.
I have converted to Ant+ and fixed it as another persons has done in the form (http://forum.elite-it.com/viewtopic.php?f=48&t=2547 ). I think there is another underlying issues that needs to be resolved.
I have ruled out any Bluetooth or PC issues by testing with my wife's Trek trainer and that works perfectly with Bluetooth with the vary same setup.
Anyone what any suggestions?
Re: Bluetooth is unstable and never worked right with Zwift
I had this issue using my laptop from 2016, connection would drop intermittently and ERG mode kicked in very slowly. Switched to the Zwift app on my phone (2018) and it works a lot better. Maybe worth a shot.
Thank you for the suggestion. This is not really a solution but a workaround. Still Bluetooth this way doesn't work properly
Users browsing this forum: No registered users and 45 guests
