Change 11 gear cassette to 10 gear cassette
Stirling1314
Hi, I’m after a bit of help, I have just ordered a Suito and a 10 gear cassette ( to match my bike ) do I need a spacer when I replace the original 11gear cassette that is on the Suito ?
Re: Change 11 gear cassette to 10 gear cassette
Yes, you have to use one spacer. You can find it in the package (there are two of them in the adapter bag)
Stirling1314
OK, thanks.
Elite Admin S wrote:Hi
I assume that using two spacers will be fine to install a 9 gear cassette.
And what about a shimano 8 gear, like the Acera ? Would it be possible to install it if I manage to have three spacers/adapter ?
thanks
diego
Yes I have the same problem, all my bikes have 8 speed cassettes so will the Turbo Muin Smart B+ take a 8 speed cassette with three spacers.
We don't support 8 speed cassettes, but some users have been able to install it anyway using proper spacers.
You can check it with your trusted mechanic, but please notice that we cannot guarantee that the gear will work properly. Also, the chain and cassette may be damaged over time.
rolandkengen
I also want to change the 11 gear cassette to a 9 gear cassette, so I understand I have to use 2 spacers. Where do I have to put the spacers
red.hell@libero.it
on the freewheel of the trainer, before install the cassette
but the width of 9 and 10 speed cassette is the same, I used 2 spacer for a 10 speed cassette
